Refile problem
Refile problem
Refile problem
we have 120000 files parts to convert to the new NX8 version.
100000 files was refilled successfully, but 20000 have error during the refile.
GTAC hasn't find the problem and then the solution.
We came from NX7, so I ask if the open-save-close file has the same result of refile.
I read about the John argument on the lightweight faceted regeneration that use or not use the part tolerance, but sincerely I didn't understand if some customer default setting can produce the same result like the refile during a simple open-save-close file.
Maybe an open-save-close file is better then nothing ?bigsmile
I would like to take advantage of the lightweight because on the refilled part the time to open and save big assembly is impressive.
Thank you...
Using NX 8 and TC9.1
RE: Refile problem
Opening a file and resaving it is certainly better than doing nothing.
As for the lightweight representations, without using the refile option, it takes a lot of extra work to get the new lightweight representations to use what might be a better set of default tolerances than what the legacy models were originally created at.
To do it manually, which means while doing the 'open & save' workflow, you would have to, after opening the file, go to...
Assemblies -> Advanced -> Representations...
...and manually delete any existing 'faceted' models (i.e. 'representations') and then reset the tolerances BEFORE saving the model, which would then create new 'representations' using these new tolerances. However, this requires an 'Advanced Assemblies' license, while running refile and using the option to completely replace the old 'representations' with new ones based on the new Customer Default tolerances does NOT require any special license.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Refile problem
Thank you John, this information is very useful.
Thank you...
RE: Refile problem
John... (from memory), isn't there a Customer Default setting that Deletes the Legacy Representations? E.G. Assemblies | Site Standards | Lightweight Reference Set Removal Remove All
or does this not do what is required by this user?
NXherbie
NX7.5.3 / TCe 2007
RE: Refile problem
Removing the Lightweight Reference Sets is NOT the same as deleting the Lightweight Reprensentations. This is merely an option which allows you to do a little 'housekeeping' since starting with NX 7.5 there was no longer any need to maintain separate Reference Sets, one for the exact model and one for the lightweight version. This Customer Default option simply allows the user to control whether he wishes to retain these now obsolete Reference Sets are not. The OOTB default is to remove them, but since some customer may have developed custom workflows based on having these Reference Sets available, this option was added to allow them to keep them intact. But. as I've already stated, this has NO impact whatsoever on the legacy lightweight representations (i.e. faceted bodies) themselves.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
