filling the gap between thermowell and RTD?
What can I use to fill the 1/4" gap between the tip of an RTD and its thermowell? something that can be readily available anywhere, like grease, etc..? it is installed on an air duct, temperatures are low, 60 degC max. thanks for your advise.
RE: filling the gap between thermowell and RTD?
TTFN
http://www.rtdcompany.com/technical_info/Install_r...
(2B)+(2B)' ?
There are a zillion others available -- google "thermally conductive compound"
It's made for just this purpose. Be careful to apply it so that it doesn't run and leak everywhere. If your sensor goes in a well or tube, keep it pointing down or else pack/plug it.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Best to you,
Goober Dave
It used to be common for a probe to reach the centerline of the pipe however if you're not carefull it's possible to have the probe vortex which is not good. Two inches into the flow stream is enough, most modern RTDs only measure with about the first 1/2 of the probe.
Best to you,
Goober Dave
