Submersible 3-4:1 90 degree reduction gearbox with streamlined casing
Does anyone know of individual units that can be bought for trial purposes other than those on the bottom of most outboard engines which seem to have a reduction ratio more like 2:1
RE: Submersible 3-4:1 90 degree reduction gearbox with streamlined casing
If you can using an electric motor there are several options for gearmotors for the input here -
http://www.leeson.com/Literature/Grove%20Gear%20Al...
It also mentions "ratio multipliers" "available in cast iron with ratings to 20 HP and ratios from
2:1 to 7.5:1."
RPM = 1500-2000
It would be 1000x more ideal if the gearboxes was able to engage and disengage without the need for a clutch. I have been looking at bevel gearboxes but most are very heavy duty and what I want is light and efficient.
