Load related geometry in assembly constraints
I'm using NX8 and in the assembly load options I've set to use lightweight and partial loading on.
Sometimes I add constraints from components that have entities visible only in the entire part, like sketch entities or planes.
The problem is when I open this assemblies.
The assembly show the exclamation symbol near to the assembly name and the clock in the out of date assembly column.
The exclamation symbol and the clock go away if on the assembly constraints group I make 'Load related geometry'.
Exist a global option to load related geometry automatically without lose the performance gained with lightweight and partial loading option on ?
Thank you...
Using NX 8 and TC9.1
