Small Engine 6.5 Tilting
Hi Guys.. I need advice.
I have purchase a Briggs and Stratton Vanguard 6.5HP Horizontal Engine (w/ splash lubrication system / motorsports rod dipper design).. I want to tilt it to power a small boat's propeller... the manufacturer does not recommend it ( but I've seen similar small engines being tilted in operation...
what angle from horizontal do you think I can get away with w/o causing engine failure/long term maintenance issues?
It will be operated daily, 10-12 hrs
RE: Small Engine 6.5 Tilting
Do you think B&S will warrant the engine if _we_ say it's okay to run it in positions they don't support?
Mike Halloran
Pembroke Pines, FL, USA
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
A tidy mind not intelligent as it ignors the random opportunities of total chaos. Thats my excuse anyway
Malbeare
www.sixstroke.com
... already done, with a negative answer.
Note that the OP is asking for some assurance of trouble- free long term operation, while pushing a boat for 10..12 hours a day. Pushing a boat is hard duty for any engine; doing it all day is much harder.
I am aware of only one common application for air cooled engines in marine service; what you might call 'longtails':
http://boghogmudmotors.com/features/
You will notice that this particular apparatus includes a u-joint between the motor and the shaft, angled a bit so the motor can sit level while the shaft angles down toward the water. Maybe they listened to B&S.
Longtails are common enough that there may be engines adapted specifically for them; apparently B&S has chosen to not serve that market.
Such an engine, to survive with a simplified shaft arrangement, would need an oiling system capable of running at a tilt, and possibly also a thrust bearing (that I doubt is present on a generic B&S) to react the propeller thrust.
Mike Halloran
No where near enough information has been provided to risk contemplating modifications or especially to risk going directly against advice already given by the manufacturer.
It is a blatantly stupid question asked by someone who would know better if he was any sort of even amateur engineer. I mean, RTFM is pretty basic, but then to ignore it and ask for advice that directly contradicts it, give me a break.
If an answer where to be considered good drawings of the existing oiling system are very obviously required. Even then. 10 hours at high load with a splash feed.
But your correct Clive. I should have just red flagged it without comment.
Pat
for site rules
I have two B+S engines here, a horizontal and a vertical. Both look similar externally. Id buy both kinds if I was you, pull apart, study, and then try 'merge' design considerations taken into account on both at time of design to run at whatever angle you have in mind.
Obvious design considerations would probably be :
Oil level,
Splash fork style/comparisons,
Oil return from head considering 6.5hp is OHV,
Carb leveling when tilted,
And last, the oil drains from bearings,
Taking into account, that the 'similar' Honda 5.5hp runs OHV and comes in horizontal, and vertical layout, and that the Carting guys convert them all the time by :
making a different splash fork,
turn carb 90deg,
and lastly fill and file new bearing oil drain holes
: I think addressing any problems 'yourself' should be easy for any angle you want to run it at. But, you will have to strip and figure it out using 'your' head.
Asking here is daft as Pat mentioned, because we cannot know what is going on inside it when you consider the points I listed.
I would re-ask the same question on a carting forum, or perhaps forestry/farming website as they are a popular engine, and run in a lot of self built machines.
Be aware as mentioned, of any trust issues that the crank may see from prop.
Brian,
Also, perhaps it is not stupid:
1. Economics, is reason one. Engines are cheap, fuel not: The best engine from B&S is the Vanguard ( warranty is 3 yrs), cost around $300. The fuel cost yearly at 12 hours daily, 1.5 liters/hr), about $8,500. If I can tilit the engine, and therefore power my propeller directly, I will avoid 5-15% transmission losses (from a pulley-belt system, a CV joint or a gear box), at say 10%, that's $850 (enough to raplace the engine 2.8x / yearly)
2. Secondly, its been done before:
a. IRRI, the International Rice Reasearch Institute, developed about 2 decades ago, an axial flow pump, which is directly coupled to tilted 5, 8 and 10 Hp engines (no brand in particular). From their drawings, I can see that the tilt is between 30-45 degrees.
b. The pump IRRI developed according to them was an improvement of similar pumps prevalently used in Asia (with tilting of engines. In Thailand, it was called the long tail pump... IRRI says its the one mechine that doubled their rice production due to the improvement in irigation.
c, Small boats in Asia are powered by small (5Hp) engines, tilted!
Lastly, for what it is worth:
1. Try to keep the forums "friendly", its great to share.. both questions and answers !
2. On manufacturers' recommendations: "Malathion" was recommended as a pesticide, disabling babies worldwide while Polio Vacination was initially discouraged ... at times just keep an open mind.
cheers..P
Manufacturers are always irresponsible in their recommendations. TAKE NO NOTICE OF THEM. They are only trying to milk you for extra money on a higher spec engine.
Based entirely on the information you provided, I can confidently say there is no need to worry about the oil control system design, it simply splashes oil. What could be simpler. No matter what angle you run it at some oil must end up splashing around I guess.
Same deal for the thrust. The main bearings are designed to carry the full power of the engine, so don't worry about it. Mike is just a boring old fart who is negative about everything. His years of experience with installation of engines in boats means nothing. I would just blow him off.
Just bolt it in and run it, no worries mate.
Pat
for site rules
Not wanting to sound rude, or 'well off' - far from it, but at 300dollars per engine what have you got to lose? At that money they are 'almost disposable' should the 'r+d' prove difficult.
You have to ask yourself, 'is anyone going to die if it stalls' if the answer is no, then I dont see a big deal with 'you' trying a few things. If you wanted to run a tilted Cat engine for use with a hospital generator then that would be very different.
On another note, the durability of these small engines is not to be sneezed at. I once ran a briggs coupled to a generator for around 6hrs at full load with hardly any oil inside - it had drained out during transport. The engine didn't seize. I happened to check it 6hrs in for oil, and to my amazement, the little oil that was left had turned into what looked like mercury. I topped it up, and its still going strong since 11yrs later.
Extremely bad engine practice, but they are tough little units indeed.
@hydroman, Ill post a picture shortly that will make you smile, I run a similar cobbled together backup engine beside my 'mostly reliable' factory built mercury speedboat engine. Ive only used it 3 times when the mercury failed, but boys it beats rowing.
Brian,
A final word paskee, this is a professional engineering forum, where professionals ask questions, and receive professional answers.
In light of this, your question has come across as a little amateurish which doesn't go down too well as this is not that sort of place. But, because its nearly Christmas, Pat just 'might' let this one run,
Other forums that your question may receive a better response could possibly be, madmodders, practical machinist, or a good search through google info.
Brian,
...for a number of reasons, including (1) Cat offers genset engines that are capable of running w/significant tilt and (2) they can tell you how much tilt is acceptable and what will go wrong if you exceed it which (3) is made possible because they're getting a lot more than $400/ea.
The splash feed I think is more critical to oil level as it can't really pick up from the bottom of a deep sump, but once again that's a guess.
I really expected this thread to disappear, especially seeing the amateur quality of the OP and my curt/sarcastic reply 17/12. I have red flagged my post and requested the entire thread be looked at.
Pat
for site rules
The universal joint might just do it. A manufacturer (Lovejoy) specified it for up to 15 degrees. Do you (or any one) have an idea how much losses (power in %) a universal joint will consume? Belts and pulleys, according to manufacturers lose about 5-7%.
As Mike Halloran stated, propellers generate thrust. It's kinda basic to how they work and is one of the main issues in "marinising" an engine.
Pat
for site rules
Pat
for site rules
Brian,
All of our engines are safe to operate at no more than a 15 degree angle of operation.
Mike, Briggs & Stratton Answer Center
Last week, person I talked to at Briggs, just said "we do not recommend it" . I pursued and wrote to their technical support center, knowing that the Asian do it (tilt their engines).. I received the above reply , and I like to share it with you guys.
BUT .... I'll test the engine I bought with a universal joint to get to my desired 22 degrees tilt. As some of you suggested , I will place a thrust bearing between the engine and propeller ... I think this is safe, inexpensive and prudent. If everything test well (in a month or two)... I will start producing about 100+ units (that is why the economics !) .. its for our farm operations ... we raise fish on a 200 acre farm.
Thank you to those who contributed... I like these forums, their great! I wish I can return the favor.. I will if anybody likes to consult on "water engineering" in particular, agriculture in general.
Again, thanks..
The link you sent.. "the Hog Mud" ... was great... it gave me the solution on how to "structuraly implement / put together" the inclined pump I am designing... I saw that they included a universal joint --- it will solve 2 probles: gives me the extra 7 deg (15 vs 22) I want and facilitate ease of alignment in fabrication and field repair !!!
Thanks, P
http://www.everythingmuscle.com/1972_Corvette_Phot...
