Journal - AskPointContainment
A small program, a big problem:
error message: "Expression does not produce a value"
From the reference guide:
Returned status of the point on the body
1 = point is inside the body
2 = point is outside the body
3 = point is on the body
What is it?
CODE
Option Strict Off Imports System Imports NXOpen Imports System.IO Imports NXOpen.UF Imports NXOpen.ASSEMBLIES '- - - - - - - - - - - - - - - - - - - - - - Module NXJournal Public theSession As Session = Session.GetSession() Public theUI As UI = UI.GetUI() Public theUFSession As UFSession = UFSession.GetUFSession() Public workPart As NXOpen.Part = theSession.Parts.Work Sub Main Dim theSession As Session = Session.GetSession() Dim theUI As UI = UI.GetUI() Dim pointPos as Integer Dim aPoint As Double() aPoint(0) = 11 aPoint(1) = 0 aPoint(2) = 12.5 For Each aBody As Body In workPart.Bodies Dim a as integer = theUFSession.Modl.AskPointContainment (aPoint, aBody.Tag, pointPos ) Next End Sub End Module
What is it?
kukelyk
RE: Journal - AskPointContainment
CODE
Dim a as integer =theUFSession.Modl.AskPointContainment (aPoint, aBody.Tag, pointPos )www.nxjournaling.com
kukelyk
