Femap Contact to MSC Nastran
Hi all,
Is it possible to generate an MSC Nastran "file.bdf" containing contact parameters created using Femap 10.3? is there some cards or parameters to add?. Did MSC Nastran 2012 take into account contact analysis generated by Femap?.
I tried to investigate this using a model that Blas puted on his website to explain how we can run a contact analysis in Femap (using Advanced nonlinear static).
I attached the model to better undertstand:
http://files.engineering.com/getfile.aspx?folder=d...
Best regards.
Best regards.
