ASME code stamp
ASME code stamp
This is kind of like the chicken or the egg question.
If a vessel is designed for over 15 PSIG and operated at less than 15 PSIG is an ASME stamp required?
RE: ASME code stamp
RE: ASME code stamp
keep in mind jurisdictional/national regulations and law.
most, if not all, european countries dont mandate stamping.
RE: ASME code stamp
So then, would not the operating pressure govern and not the design pressure as to whether or not the vessel requires a stamp?
RE: ASME code stamp
U-1(h) vessels not exceeding the design pressure (see 3-2), at the top of the vessel, limitations below, with no limitation on size [see UG-28(f), 9-1(c)]:
(1) vessels having an internal or external pressure not exceeding 15 psi (100 kPa);
UG-28(f) simply says that vessels intended for service under external design conditions of 15 psi or less can be stamped ... denoting compliance with the rules for external pressure.....
RE: ASME code stamp
