Mass Attribut on Part List
In NX8 it's very easy to add a column with mass on each component
But
How to do this in NX7.5 because the attribut function is not the same ?
TIA
But
TIA
Didier Psaltopoulos
http://www.psi-cad.com
RE: Mass Attribut on Part List
You can see the attributes available by clicking on the arrow at the end of attribute name.
Anthony Galante
Technical Resource Coordinator
NX5.0.6, NX6.0.5, NX7.5.0-> NX7.5.5 & NX8.0.0 -> NX8.0.3.4, NX8.5.0.23
It seems that this attribut have an effect only with large assemblies module, but I have only a MACH2 license
Did you have this module ?
Didier Psaltopoulos
You need to make sure that the parts have weight attributes saved.
You can use File -> Options -> Save Options & tick the box for Generate Weight Data. This will save the mass data for the part when the part is saved.
The better way is to turn on the customer default (see image). That way any part when saved will update the mass data.
Anthony Galante
Two more questions:
- How did you set the unit ?
- Have you find a way to calculate the sum ?
Thanks in advance
Didier Psaltopoulos
Anthony Galante
Thanks a lot. I can go to bed relaxed now because it too late in France
Didier Psaltopoulos
Anthony Galante
