NX 7.5 to Hypermesh 11.0, exporting as a FEM file
Hi, this is my first time here
I'm a CAE Engineer in the automotive industry, I was using NX in order to mesh a file which has a very complex geometry, then I export it as a FEM file using the Export Simulation option (Solver NASTRAN, Structural), but when I read it with HM, the file doesn't load
Thanks for your help
RE: NX 7.5 to Hypermesh 11.0, exporting as a FEM file
The first thing you must to check is if your model solves correctly when you launch the analysis from inside NX 7.5, I suppose you use NX Advanced Simulation with NX NASTRAN as FEA solver. If your model is correctly defined then solution will be performed successfuly, not matter if you mesh with solid or Shell elements, then you will be able to import the NX NASTRAN deck (*.dat) in any other FE program, say FEMAP, Hipermesh, etc..
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
Best Regards
