saving outside of teamcenter
I have tried searching for this, but can't find the answer. I'm new to NX (and Teamcenter as well).
Can I save a part outside of teamcenter, so I can make an internal drawing for my personal use? I would like to do all this work in NX 7.5 for training purposes so I can learn NX. Thanks in advance.
RE: saving outside of teamcenter
When you do a save-as, can you select a disk folder instead of TC?
Ben Loosli
If you have models in TC that you would like to work with outside of TC you can find "Export Assembly outside Teamcenter" in NX file menu. With this command you can export models for native NX work.
There is however a possibility that this functionality is removed depending on your environment...
