NX - Renumber Expressions - Revisited
I see that this has been asked before - but I would like to revisit the question. Because of various importing/exporting of bits in my model it has gotten very "riddled" with primed expressions. To the point that I cannot make out the dimensions on my sketch (see attached) because the expression names are so long.
How can I renumber the expressions so that I can once again see what I am working with?
I'm using NX7.5
Jeff
I'm using NX7.5
Jeff
RE: NX - Renumber Expressions - Revisited
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
When I run the program it errors with "Error 1548999 at line 32 in Rename_Exp. No write access"
What does it need write access to?
Jeff
That being said, to get around the problem of people not having write access to the folder where NX was installed, I changed the program (new files attached) so that the temporary text file where the expression names are written is now being created in the Windows 'Temp' folder so this should now work for everyone.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Jeff
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
