Material Identification Marking
Hi Everyone,
I have a lots of fittings SA-105,which with same heat number, same class and manufacturer, only different is size. where coded marking be use, UG-77(a) requires the transfer of "the original identification markings required in the specifications for the material,is it acceptable to tracing to original marking excluding size?
Thks!
Thks!
RE: Material Identification Marking
