Flow Rate Through a Manifold
Hi
I want to select a pump for a quenching tank that has an intake manifold with 12 smaller pipe inlets to the tank. The flow rate required at the discharge is 170 m3/h, two pumps are being used with one in standby. Is it possible to calculate the flow rate for each small pipe on its own or is it sufficient to assume that the flow through each pipe will be the same 170/12 = 14.167 m3/h?
Thank you
Thank you
RE: Flow Rate Through a Manifold
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
