RESTART SOL 106
RESTART SOL 106
Hi I'm trying to restart a job because it has failed and I don't want it to run from the start because it's pretty long.
the original bdf file was this one:
SOL 106
CEND
SEALL = ALL
SUPER = ALL
TITLE = Axial_Link_Bracket_Compression
ECHO = NONE
MPC = 200
SPC = 51
$ OUTPUT REQUESTS
DISPLACEMENT(PLOT,SORT1,REAL)=ALL
SPCFORCES(PLOT,SORT1,REAL)=ALL
MPCFORCES(PLOT,SORT1,REAL)=ALL
STRESS(PLOT,SORT1,REAL,VONMISES,BILIN)=ALL
STRAIN(PLOT,SORT1,REAL,VONMISES,BILIN)=ALL
NLSTRESS(PLOT)=ALL
FORCE(PLOT,SORT1,REAL,BILIN)=ALL
$ SUBCASES DEFINITION
SUBCASE 1
SUBTITLE= Solo Preload
NLPARM = 1
SUBCASE 2
SUBTITLE=Carico al 1%
NLPARM = 1
LOAD = 50
SUBCASE 3
SUBTITLE=Carico al 90%
NLPARM = 2
LOAD = 51
SUBCASE 4
SUBTITLE=Carico al 100%
NLPARM = 2
LOAD = 52
BEGIN BULK
...... entire model
ENDDATA
I modified the restart bdf file like this:
ASSIGN MASTER='Axial_Link_Bracket_11.2KN_Compression_Master.MASTER'
RESTART VERSION=LAST,KEEP
SOL 106
CEND
SEALL = ALL
SUPER = ALL
ECHO = NONE
MPC = 200
SPC = 51
PARAM,SUBCASID,4
$ OUTPUT REQUESTS
NLSTRESS(PLOT)=ALL
SUBCASE 1
NLPARM = 1
SUBCASE 2
NLPARM = 1
LOAD = 50
SUBCASE 3
NLPARM = 2
LOAD = 51
SUBCASE 4
SUBTITLE=Carico al 97%
NLPARM = 3
LOAD = 53
SUBCASE 5
NLPARM = 2
LOAD = 52
BEGIN BULK
NLPARM 3 7 ITER 1 30 PW NO
.001 1.-7
LOAD 53 1.00 0.97 40
ENDDATA
but when I run the job I get the following error from NASTRAN:
M O D E L S U M M A R Y BULK = 0
ENTRY NAME NUMBER OF ENTRIES
LOAD 1
NLPARM 1
^^^ >>> IFP OPERATIONS COMPLETE <<<
*** SYSTEM WARNING MESSAGE 3001 (SEP1X)
THE INPUT DATA BLOCK NAMED GEOM1QS AT POSITION 2 DOES NOT EXIST.
USER INFORMATION: THIS ERROR IS CAUSED BY ONE OF THE FOLLOWING:
1. THE DATA BLOCK WAS NEVER CREATED.
2. THE DATA BLOCK WAS DELETED.
3. THE DATA BLOCK IS SPECIFIED ON A TYPE STATEMENT IN THE CURRENT SUBDMAP OR A HIGHER SUBDMAP
BUT THE CURRENT QUALIFIER VALUES DO NOT MATCH
THE QUALIFIER VALUES OF THE DATA BLOCK(S) ON THE DATABASE.
USER ACTION: 1. IF YOU ARE EXECUTING AN MSC.SOFTWARE SUPPLIED SOLUTION SEQUENCE AND NOT USING THE
ALTER EXECUTIVE CONTROL STATEMENT, THEN CHECK FOR BULK DATA AND/OR CASE CONTROL INPUT
ERRORS. IF NO ERRORS CAN BE FOUND, THEN CONTACT MSC.SOFTWARE CLIENT SUPPORT.
2. IF YOU ARE EXECUTING A DMAP PROGRAM NOT SUPPLIED BY MSC.SOFTWARE, THEN FOR DEBUGGING PURPOSES
INSERT STATEMENT DIAGON(20) BEFORE THE MODULE SHOWN ABOVE.
PROGRAMMER INFORMATION: THE FIST NUMBER IS 102 AND SUBROUTINE IS SEP1X
THE INPUT DATA BLOCK NAMED GEOM2QS AT POSITION 3 DOES NOT EXIST.
PROGRAMMER INFORMATION: THE FIST NUMBER IS 103 AND SUBROUTINE IS SEP1X
*** SYSTEM FATAL MESSAGE 6357 (SEP1A)
NO GRID POINTS FOUND
0FATAL ERROR
1 * * * END OF JOB * * *
Can anyone help me please?
I remember I've done some restart some time ago and it worked but I never got this problem.
Sorry for my english
SOL 106
CEND
SEALL = ALL
SUPER = ALL
ECHO = NONE
MPC = 200
SPC = 51
$ OUTPUT REQUESTS
NLSTRESS(PLOT)=ALL
SUBCASE 1
NLPARM = 1
SUBCASE 2
NLPARM = 1
LOAD = 50
SUBCASE 3
NLPARM = 2
LOAD = 51
SUBCASE 4
NLPARM = 2
LOAD = 52
BEGIN BULK
...... entire model
ENDDATA
SOL 106
CEND
SEALL = ALL
SUPER = ALL
ECHO = NONE
MPC = 200
SPC = 51
PARAM,SUBCASID,4
$ OUTPUT REQUESTS
NLSTRESS(PLOT)=ALL
SUBCASE 1
NLPARM = 1
SUBCASE 2
NLPARM = 1
LOAD = 50
SUBCASE 3
NLPARM = 2
LOAD = 51
SUBCASE 4
NLPARM = 3
LOAD = 53
SUBCASE 5
NLPARM = 2
LOAD = 52
BEGIN BULK
.001 1.-7
ENDDATA
LOAD 1
NLPARM 1
0FATAL ERROR
