"d" in punching shear of two way PT slabs
Section 11.5.3. of ACI 318 specifies the valiable "d" in prestressed members to be a minimum 0.8*h. In punching checks, if you elect NOT to design per 11.12.2.2 (which includes of the tendon component in the shear capacity), and instead use the typical 4rt(f'c)bd, would it be appropriate to take "d" as the average depth to the mild reinforcement? It would seem to me that 11.5.3. may not have even had slabs in mind, but moreso beams where there may not be top steel at midspan to provide confinement.
RE: "d" in punching shear of two way PT slabs
