Mass Assign Component Properties
My workplace has been using Component properties to fill in the template for a Drawing, but I see the possibility of using them to help me input data into a costing excel file combined with the export BOM function.
However neither of these component properties (Surface Area and Mass) have been used before in any existing components. Is there a way either at the assembly or even better directory level for me to add these two component properties without overwriting those which already exist.
To add insult to injury anything related to EPDM is not available at this time.
Any help would be appreciated, manually playing with BOM's is not amusing.
RE: Mass Assign Component Properties
Jeff Mirisola
My Blog
You might have to fix the missing libraries
Deepak Gupta
CSWE, CSWP, CSDA
SW 2012 SP5.0 & 2013 SP 1.0 EV
Boxer's SolidWorks™ Blog
SolidWorks™ Rendering Contest
