Get Name of component in VB when selecting face
I'm still doing research on this one but thought I'd ask before reinventing the wheel.
The idea is the user selects two groups of faces which will be checked against each other and data gathered and dumped in an external file for later perusal.
Is it possible when the user selects the first face to not only grab the face for use, but also the name of the component in the assembly, or the name of the part file if it is a work part, to be used as a file name?
So far I've had no luck finding anything to grab the name of the component, but I'm still looking.
Thanks.
RE: Get Name of component in VB when selecting face
I typically use a selected face to get its body. I then use the body to get the owning component. Finally I use the component to get the part.
Dim tempface As Face = "selected face"
Dim tempbody As Body = tempface.GetBody()
Dim tempcomp As Component = tempbody.OwningComponent
Dim temppart as part = CType(s.Parts.FindObject(tempcomp.Name), Part)
Frank Swinkels
We have really long part names on the order of
##.##.##.##_Description_REV_Date
When using the above command I am only getting the last part of the name. Is there a way to increase the string length so the entire name is saved or at least the first part of the name rather than the last part?
Does this happen to all the parts or just the ones with really long names? How many characters are in these long part names?
I have some code similar to Frank's:
CODE
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
Dim mySelectedObject As NXObject
Dim fileName as String = ""
lw.Open
'Continue prompting for a selection until the user
'  presses Cancel or Back.
Do Until SelectAnObject("Select a face", _
                       mySelectedObject) = Selection.Response.Cancel
'   lw.WriteLine("Object Tag: " & mySelectedObject.Tag)
'   lw.WriteLine("Object Type: " & mySelectedObject.GetType.ToString)
'   lw.WriteLine("")
	if mySelectedObject.IsOccurrence Then
		fileName = mySelectedObject.OwningComponent.Prototype.OwningPart.FullPath
		lw.writeline(fileName)
		lw.writeline(io.path.getfilenamewithoutextension(filename))
	End if
Loop
lw.Close
End Sub
    Function SelectAnObject(prompt As String, _
               ByRef selObj As NXObject) As Selection.Response
       Dim theUI As UI = UI.GetUI
       Dim cursor As Point3d
       Dim typeArray() As Selection.SelectionType = _
           {   Selection.SelectionType.Faces}
       Dim resp As Selection.Response = theUI.SelectionManager.SelectObject( _
               prompt, "Selection", _
               Selection.SelectionScope.AnyInAssembly, _
               False, typeArray, selobj, cursor)
       If resp = Selection.Response.ObjectSelected Or _
               resp = Selection.Response.ObjectSelectedByName Then
           Return Selection.Response.Ok
       Else
           Return Selection.Response.Cancel
       End If
    End Function
End Module
www.nxjournaling.com
If you are talking about part file names then the following applies:
"Filename Lengths: Unless otherwise stated, filename lengths are limited
to UF_CFI_MAX_FILE_NAME_LEN characters which includes
any periods or extensions. This includes directory names
and part file names. Pathnames are limited to
UF_CFI_MAX_PATH_NAME_LEN characters. Valid characters
for a filename depend on the operating system."
On my system
#define UF_CFI_MAX_FILE_NAME_LEN 128
Frank Swinkels
Is that a command added at the beginning of a vb program or is that a command that is in the environmental variables?
I found a file in the UGOpen folder called uf_cfi.h but I don't see a place to set the variable length.
From what I see when I run my program the length is currently set the 30 characters and I would like to lengthen it if I can.
Thanks.
If I can get some help with where to find where I can modify this value.
my code to attempt to change this value in vb is:
UFConstants.UF_CFI_MAX_FILE_NAME_LEN = 128
And receive the error:
Constant cannot be the target of an assignment
I have tried to find an environmental variable but I don't see it there. I have been trying to find a file that contains the information, but I haven't had any luck, though I did find one that references it it does not contain any place to modify it.
Any help is appreciated.
