Gfortran + Windows7
Gfortran + Windows7
I'm trying to get this to work with Gfortran and Windows7.
Anyone have experience with accessing the OS under Seven?
Thanks.
MODULE IFWIN
USE, INTRINSIC :: ISO_C_BINDING
IMPLICIT NONE
PRIVATE
PUBLIC QueryPerformanceCounter
INTERFACE
FUNCTION QueryPerformanceCounter(lpPerformanceCount)
BIND(C, NAME='QueryPerformanceCounter')
IMPORT
IMPLICIT NONE
INTEGER(C_INT) QueryPerformanceCounter
INTEGER(C_INT64_T) lpPerformanceCount
END FUNCTION QueryPerformanceCounter
END INTERFACE
PUBLIC QueryPerformanceFrequency
INTERFACE
FUNCTION QueryPerformanceFrequency(lpFrequency)
BIND(C, NAME='QueryPerformanceFrequency')
IMPORT
IMPLICIT NONE
INTEGER(C_INT) QueryPerformanceFrequency
INTEGER(C_INT64_T) lpFrequency
END FUNCTION QueryPerformanceFrequency
END INTERFACE
END MODULE IFWIN
PROGRAM MAIN
USE IFWIN
IMPLICIT NONE
INTEGER(C_INT64_T) lpFrequency, lpPerformanceCount
INTEGER(C_INT) I
I = QueryPerformanceFrequency(lpFrequency)
I = QueryperformanceCounter(lpPerformanceCount)
WRITE (*, *) lpFrequency, lpPerformanceCount
END PROGRAM MAIN
Thanks.
MODULE IFWIN
IMPLICIT NONE
PRIVATE
INTERFACE
IMPORT
IMPLICIT NONE
END INTERFACE
INTERFACE
IMPORT
IMPLICIT NONE
END INTERFACE
END MODULE IFWIN
PROGRAM MAIN
USE IFWIN
IMPLICIT NONE
INTEGER(C_INT) I
END PROGRAM MAIN
RE: Gfortran + Windows7
With a .lib (static library) you link it directly.
With a .dll (dynamic link library), it just has to be in the path.
On my system, kernel32.ddl is buried in the path.
Anyway, my errors are related to the variable types, supposedly coming from ISO_C_BINDING.
C_INT isn't understood by the compiler.
Any ideas?
