Dual Dimensions
Dual Dimensions
Time for another dumb question.
I am using Catia V5R20, how do I do dual dimensions with inches over metric?
Thank you in advance for the help.
RE: Dual Dimensions
In the meantime, you can change dimensions to make them dual:
1. create the dimension
2. right-click on the dimension and go to Properties, and go to the VALUE page
3. turn on the DUAL DIMENSION option
4. choose a dimension style for the primary value (NUM.DINC is often used for inches)
5. choose a dimension style for the secondary value (NUM.DMM is often used for millimeters)
6. set the decimal places and other properties, and OK when done
