Approximate Cost to go under a street to get at the sewer line
I am looking to put together a budget for a property that I am considering building a home on. The water service is on the same side of the house, the sewer service is across the street. Approximately how much extra will it cost to have to go under the street to utilize the sewer?
RE: Approximate Cost to go under a street to get at the sewer line
Seriously, if you want a real answer, you need to do some homework and I recommend getting a quote from a local contractor. My answer is about $2k extra
1. Western Suburbs - Cook County
2. Local Street
3. Asphalt
4. maybe 2 lanes, quiet street (30mph?)
5. Not sure how deep (just assume standard)
6. Not sure if it is PVC or VCP (assume more expensive)
7. Assume no.
Thanks. I appreciate it.
You are absolutely correct. I meant "main" not "service". This lot is not part of a new development. It is a teardown for a house that was built in the 50s. So I was hoping to get an opinion on a price assuming the stub was not there.
Thanks.
Does it have a crawl space/basement where you can inspect the pipe(s)?
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
Richard A. Cornelius, P.E.
WWW.amlinereast.com
WWW.amlinereast.com
My Mom's friend lived on a major artery in LA, Sepulveda, and she was getting quotes for replacing the line in the street portion for $100k!!!
Why do you need the line? Are you on septic currently?
B+W Engineering and Design
Los Angeles Civil Engineer and Structural Engineer
http://bwengr.com | http://bwstructuralengineer.com | http://bwcivilengineer.com
