Professional Advice on Matrix and Fiber Interaction
Dear professional and experts
I would like to ask you regarding the interaction between fiber and matrix at micromodelling level of composite, CFRP T800 used in most of aircraft application
is it cohesive at the interface between the matrix and fiber? or just normal tie constraint?
many thanks in advance for your reply and insight, really appreciate it
RE: Professional Advice on Matrix and Fiber Interaction
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
Brian
www.espcomposites.com
are you saying that assuming perfect bonding and zero thickness cohesive interaction?
can you advice what do you mean by coincident mesh?
many thanks brian, you are a star = )
regards
isyhadh
many thanks for your advice
in terms of fracture mechanics and numerical simulation, is there any big difference between cohesive interaction with separation when the interaction becomes more than traction toughness, and another case is tie constraint in the initial and beginning then implying penalty for normal and shear direction (friction) to allow separation after interaction
hope you understand what i mean
many thanks for your expertise
regards
isyhadh
