Nozzle reinforcement deisgn question
Hello:
Having a question about nozzle reinforcement design. It is a 4" NPS coil installed inside one pressure vessel . The coil nozzle penetration through the vessel. The vessel and internal coil are designed in accordance with ASME VIII DIv 1. Coil internal design pressure is 200% higher than design pressure of the vessel. My question is when we do nozzle reinforcement design for coil nozzle on the shell, the trn - required thickness of nozzle wall is based on pressure vessel design pressure or coil internal design pressure. Please advise. Thanks
RE: Nozzle reinforcement deisgn question
Mike
gr2vessels
