Help needed for Abaqus Eplicit, I need your expertise and advice
Hi there,
Good day everyone
I would like to ask your advice and help
I have successfully run and simulated several abaqus standard cases with static loading
Now i want to convert all the files into dynamic loading which is impact loading which requires abaqus explicit
unfortunately i faced and encountered string of aborted and errors
can you advice in interaction tie geomtery, what are the most important to note if i want to convert from standard to explicit
I have changed the step - from static to dynamic explicit
i put the amplitude rather than ramp for the loading option
i have changed the meshing type from standard to explicit
what else i have to change?
many thanks thanks
really appreciate your help and assistance
Good day everyone
many thanks thanks
RE: Help needed for Abaqus Eplicit, I need your expertise and advice
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
really appreciate your reply
as per attached are the report .dat error details
many thanks
isyhadh
