Regarding CAESAR II Load cases
Dear all,
can any one tell me that how to build a load cases for a piping system in B31.3 code. Apart from basic load cases is there any procedure to build a combination cases and also i want to know function of Algebric, scalar and SRSS combination methods.
RE: Regarding CAESAR II Load cases
Assuming you have access to Caesar II, your queries are covered in the User Guide, Applications Manual and Technical Reference Manual. Also the Quick Reference Guide. All these are supplied with the software and are contained in the Caesar directory, typically Intergraph CAS\Caesar II 5.30\C2_docu as on my computer. Files are avaiable on screen in pdf format and can be conveniently assigned to a menu short-cut.
C2it,
thank you
