recommended materials for a component part
Attached are two drawings . . . one shows the dimensions of a " frame " piece the other shows what the padding looks
like that will fitup under the frame. My question is rather than using aluminum for this frame, what would be the best
plastic or composite to use ? I am looking for extreme strength, lowest cost per piece, and flexibility to have different colors.
The thickness of the frame should be no more than 1/4" to 5/16" the width of the frame will be 3" and you can see the angles that it will need to be bent/shaped to. this piece hapens to have (3) 5 inch sections and their will be another
piece that will have (3) 7 inch sections with similar angles.
look forward to hearing some opinions.
Bill
RE: recommended materials for a component part
The file wont download, but going blind my first reaction is painted steel as strength price and colour are requirements for car bodies and metal cladding and roofing profiles
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
"extreme strength, lowest cost per piece, and flexibility to have different colors."
Engineers design with specifications, not superlatives. A toothpick has extreme strength compared to a wet noodle.
TTFN
