Missing dimensions in drawing
Hello.
We have met a issue more times, where Show Model Annotations in drawing doesn’t work properly.
The first picture shows dimensions of hole in Revolve feature in the model.
The hole is fully constraint and all dimensions are strong.
(This particullar hole is in pattern of 3 holes, but we have met this issue in many cases with another single features and models.)
The First picture - a hole in the feature
http://files.engineering.com/getfile.aspx?folder=8...
In Second picture you see dimensions which are shown by Show Model Annotations.
As you can see, there are two of dimensios which are missing (d3.7 and d5.3).
The Second picture - a hole in the drawing
http://files.engineering.com/getfile.aspx?folder=e...
Have you ever met this issue?, possibly, what is the right procedure of showing model dimensions in drawing?
Thanks for aswer.
