Foundation Works
Foundation Works
I've got an instruction from our consultant that i don't understand the logic behind... based on the geotechnical report, we can excavate up to 1.5m from the natural grade level to achieve the needed soil bearing capacity but we must excavate 50cm more and backfill in two layers, 25cm per layer and compact up to 95% to prevent settlement. I really don't get why we have to backfill when we can have the 1.5m depth of excavation compacted up to 95% without backfilling or have the 2.0m depth compaction and have it compacted up to 95% and rest my footings there. as per our consultant, he said that soil bearing has nothing to do with settlement but what affects the settlement is the soil properties that's why we need to backfill a good material to serve like a spring that would receive the settlement... can anybody enlighten me regarding this matter? because as my experience, footings or foundations are rested on the natural ground level after excavation and no more backfilling only compaction...
RE: Foundation Works
