Using Check-Mate to verify if holes are aligned
Is it possible to use Check-Mate to verify if two or several holes have aligned center lines? Possibly by finding all center lines with endpoints within a given range and checking in these center lines are aligned? I realize there is no OOTB check for this, but are there functions that would enable writing a custom check that works in this way? Does anyone have experience of a check that works in a similar way?
RE: Using Check-Mate to verify if holes are aligned
http://dfmpro.geometricglobal.com/products/userdet...
Thank you...
Using NX 8 and TC9.1
