Snug tight on a multiple bolt connection
For snug tightness, when verifing that the plies are in firm contact when several bolts are holding the plies together, does AISC require that all bolt heads be in contact with the ply?
thread507-297476
RE: Snug tight on a multiple bolt connection
All bolts must be snug tight. Per RCSC, snug tight requires that bolts must be sufficiently tight that the nut cannot be removed without a wrench. This would imply that the nut and head are both in contact with the outer ply. Or in contact with a washer which is in contact with the outer ply.
It is not uncommon to find it necessary to retighten bolts after other bolts in the connection are tightened.
www.FerrellEngineering.com
Providing fabrication and erection efficient structural design of connections. Consulting services for structural welding and bolting.
