Alias Fit curve command equivalent in NX 8.5
Just a quick question is there any command in NX 8.5 that would be equivalent to the fit curve command in Alias.Used to build a curve usually on a trimmed edge where you want control over the parimterization
and the deviation in order to build more surfaces from?
Thanks, Buddy
Thanks, Buddy
RE: Alias Fit curve command equivalent in NX 8.5
I have not succeeded in doing it on an edge directly.
Tomas
Insert -> Associative Copy -> Extract Geometry...
...to 'extract' a 'Composite Curve' of the body's edge, which can then be referenced when creating a 'Fit Curve'.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
