How to retrieve Created and Modified time of features in the part navigator using NXOpen ?
Hello Everyone ,
Can someone help me out with a sample code on how i can retrieve the created and modified time of all the features in the part navigator using NXOpen in NX 7.5?
Thanks and Regards,
Amitabh
Thanks and Regards,
Amitabh
RE: How to retrieve Created and Modified time of features in the part navigator using NXOpen ?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Well in that case i am interested in knowing as to how i can retrieve the modified and the created date using NXopen of all the features in the part navigator.
Amitabh
Don't know if you can get the that information directly, but you can use the "theSession.information.displayfeatureinformation()
method and redirect the information window output silently to a temporary file that you then read, parse and delete.
1. Use a NXOpen function or the equivalent wrapper function to get the part history creation version number and last modified version number for the object
int UF_OBJ_ask_cre_mod_versions
tag_t object,
int * creation_version,
int * lastmod_version
2. Use the part history to get the dates and time.
int UF_PART_ask_nth_history
UF_PART_history_list_p_t history_list,
int index,
char * * program,
char * * user,
char * * machine,
int * version,
int * gmtime
Frank Swinkels
Amitabh
I implemented the wrapper functions as mentioned by you.
But the second wrapper function gives the part history and not the feature history ehich i am actually interested in, can you let me know how can i get the feature history (of all the features in the part navigator)
Regards.
Amitabh
For each feature in work part call UF_OBJ_ask_cre_mod_versions
This will return the creation_version (ie the part version when the feature was created)
and return the lastmod_version (ie the part version when the feature was last modified)
Now call UF_PART_history_list_p_t history_list and use creation_version to get gmtime for the
feature creation and call UF_PART_history_list_p_t history list and use lastmod_version to gmtime for the feature last modified.
Hope this helps.
Frank Swinkels
This really helped and i am able to get what i had ventured out for.
By the way Wish you a Very Happy New Year.
