some intersting questions
how the speed of aeroplanes is measured?
eventhough coccnut water is well surounded by shell what makes the noise when we shake the cocunut?
how to select refrigerants?(whetehr wate can be a refrigerent(economical compared to brine/gycol) for colling to (12C)
RE: some intersting questions
Skipped the first question.
Sound travels through anything except vacuum. When you shake a coconut vibrations created will cause sound and the sound passes through the shell and coir and to your ear.
Brine/Glycol are not generally called as refrigerants. They are cooling media. If your application is above 5 deg.C use soft water as cooling medium rather brine for specific heat of water is higher than any brine. (Note: freons are called refrigerants for example)
There are other ways too.
Excessive accuaracy is a sign of poor breeding. -Socrates.
TTFN
Due to impact noise are created.
