Shaft Voltage measurements
I am looking for a simple means of measuring shaft voltages for EDM investigation.
Any recommendations?
Best regards,
Mark.
Best regards,
Mark.
Mark Empson
Advanced Motor Control Ltd
RE: Shaft Voltage measurements
Another version uses a large custom-made split CT around the shaft at the bearing to measure shaft current via a special relay. Current here indicates a bearing insulation fault. This I believe was a patented system by ASEA which was standard on their hydro generators.
It is also often that the brush at the NDE end is used for directly grounding the shaft, if no supervision of the shaft voltage is applied.
rasevskii
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
