SS316 vs SS316L
SS316 vs SS316L
I understand that the difference between SS316 and SS316L is the amount of carbon content in the material. It is in less percentage in 316L than in 316. And CF3M and SS316L are the same except the latter is forged and the former is cast body.
This difference, is it only valid when there is welding involved or does it also makes a difference in the kind of medium in the pipelines.
In one of the projects we are working on, we have proposed to use SS316L valves for all socket weld types (because of welding involved between valve and pipe) and to use SS316 valves for RF valves (no welding required, valves will be bolted to mating flanges).
Is this reason good enough?
RE: SS316 vs SS316L
Some difference in strength allowable between L and standard forms but there is dual rated materials.
RE: SS316 vs SS316L
Katmar Software - AioFlo Pipe Hydraulics
http://katmarsoftware.com
"An undefined problem has an infinite number of solutions"
RE: SS316 vs SS316L
RE: SS316 vs SS316L
Cloa - can you please elaborate "propensity to sensitive stainless steel".
The medium in the pipelines is Jet Fuel. My line size is 2", And the pipes used are 2" SS316L , Sch 40 with mating Flanges 2" 150# RF F316L, B16.5
The chemical compatibility of Stainless Steel - 316 with Jet Fuel comes as "A-Excellent" as per http://www.coleparmer.com/Chemical-Resistance
Appreciate your help!
RE: SS316 vs SS316L
Any addition with 'Ti' for titanium content in 316 material is also for improved mechanical forming by turning etc.
RE: SS316 vs SS316L
RE: SS316 vs SS316L
Get help and return with helps!!.
