mixing vessel
mixing vessel
mixing vessel
Dear friends,
A friend of mine has a doubt could anyone pls suggest or comment over it.
Solvents like Diesel and Naptha are pumped from storage tank ( 100 cbm) to mixing vessel ( 25 cbm).
Can you please suggest whether the solvents can be pumped and fed from top of the mixing vessel or from sides of the mixing vessel?
RE: mixing vessel
What is your friend's doubt?
RE: mixing vessel
"Can you please suggest whether the solvents can be pumped and fed from top of the mixing vessel or from sides of the mixing vessel?"
This is not clear to me. Attach a sketch of the choices.
Good luck,
Latexman
