scientific paper
scientific paper
I been asked to write a scientific paper about my last process control application for implementing online heat exchanger efficiency calculation for each heat exchanger in Crude distillation unit in Invensys DCS system graphic displays, the efficiency value will be updated every 1 minute and displayed as % beside the heat exchanger to the operator in the crude unit graphic displays.
Please guide and help me step by step in how to write a scientific paper and how to publish it.
RE: scientific paper
Good luck,
Latexman
They all seem pretty touchy about the abstract. SPE for example has put a minimum length of 200 words (max 500 words, but the minimum is new to me). Don't hose that or you are wasting your time. A committee made up of equal parts never-competents, and used-to-be-competents will review your abstract and decide to accept (rare) or bin it (90%+). Most of what the conferences are looking for is the perception that their members are actually doing something. I've had a half dozen out of the box papers rejected because they were "too controversial" for SPE or ASME. The committee's seem to want the appearance of advancing knowledge without too much boat rocking.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
