800 KVA Power Generator Test
I have to test a 800 KVA Electric Generator recently adquired.
Is a brand new one and is  powered with a Diesel Engine having full electronic fuel injection control.
How can I find information about standarized test procedures for:
Voltage Regulation
Frecuency Regulation
Standards points to test for resistive and inductive load
Neutral to ground differential protection
Standard grounding tests
Technical data is:
Power : 800 KVA
Voltage: 3x380 + Neutral
RE: 800 KVA Power Generator Test
Suggestion: Ask the manufacturer for the factory tests, and which standards they adhere to.
