Using APDL code in command object in Mechanical to obtain thermal results
Hi, I made nonlinear transient analysis in a plane strain 2D model. Can anybody explain how to use APDL snippets to obtain thermal results. During bending a temperature will increase in the steel sheet, and start distribution vs time. Can anyone develop APDL code?
I attached my sample on the link bellow.
RE: Using APDL code in command object in Mechanical to obtain thermal results
