NX8 Part to Parasolid
Is this functionality included in the base NX8 Llicense? I need to export some NX8 parts and assemblies out into
Parasolid files. When I go to Files --> Export --> Parasolid, a little box pops up to give the file a name, I select the data
and hit OK, the little box disappears and nothing happens. What step am I missing?
i shoudld note that this installation has no acces to the Internet and the Help files that came with this license are really crap.
RE: NX8 Part to Parasolid
The Name input on the first pop up box allows you to select an entity by name, so if you had a solid body and gave it a name of MYPART, you could type in MYPART to the first box to select the solid body. If you have not named anything in your file, use a normal selection method (single pick, window, etc) to specify the objects you want to export.
www.nxjournaling.com
