Assembly configurations
I've got an assembly that has a part that telescopes in and out and I want to show a it in both states, fully extended and compressed. What's would be the best way to do this?
I'm thinking by using a configuration in the assembly but I'm not really sure how to make it happen the way I want it to. Any help would be greatly appreciated. Thanks.
RE: Assembly configurations
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
1. Default - Uses your Limit Distance mate & is your flexible or working configuration
2. Installed Min - for drawing use
3. Installed Max - for drawing use
you can couple these configurations together in the same view on your drawing using 'Alternate Position View' feature.
http://help.solidworks.com/2012/English/solidworks...
Have you taken a look at the tutorials available in the help section of SolidWorks? They will go a long way to helping you answer your "how do I.." questions.
Jeff Mirisola
My Blog
Yes I've looked thru the help sections of SolidWorks. Maybe in tis instance I should go thru this certain area again.
Link
Link
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
