DC motor ripple voltage..
hi folks...
im working with dc motors; this i want to clarify:
1.) in uncontrolled-rectified power supply, What is the percentage tolerance of RIPPLE VOLTAGE associated with the rectified power supply to the dc motor windings?
2.) in exceed with this tolerance, if any, does it really creates audible audio disturbance(electrical humming sound) or even unusual vibrations on the machine?
3.) If it really creates disturbance, what would it then result to?
4.) how can we reduced, if not illiminated, or protect the machine out of this phenomena? any recomendations?
5.) in exceed with this RIPPLE VOLTAGE, does the winding itself can reduce or compensate such ripples by using the winding as a filtering device to smoothen the dc supply, knowing the fact that dc windings are inductive?
ill appreciate your comments and suggestions..
thank u very much.
regards.
thank u very much.
regards.
RE: DC motor ripple voltage..
fbjavier (Electrical) Oct 6, 2002
hi folks...
///The percentage of ripple is dependent on the power supply number of phases, and ripple filtering.\\\
///Most likely, it will.\\\
///Noise may be controlled by OSHA or equivalent agency, and vibration reduces the lifecycle of the equipment.\\\
///The better filtering of the ripple, increase number of phases, e.g. from one to three, from three to six, etc.\\\
///The ripple is effectively reduced by a capacitor element in the ripple filter.\\\
http://www.elevatordrives.com/elevator/resources/dsd412_app106_ripplefilter.pdf
http://www.quio.wtal.de/motorkartenleser/download/MTM-5H-0101.pdf
http://electron.toulouse.iufm.fr/iufm/Documentation/Perche/L292_b.pdf
http://www.infineon.com/cmc_upload/documents/025/392/SAE_01_MotorEMC_e.pdf
etc. for more info
