Catia V5 - 3D Annotation
I'm working on a Product file.
Do I need to keep the 3D Annotation of the components on Show? Or should I keep them in Hide?
Thanks!
Thanks!
MZ7DYJ
RE: Catia V5 - 3D Annotation
MZ7DYJ
The 3D Annotation was created before, by a previous user. I have never used 3D Annotation!
MZ7DYJ
Mark
MZ7DYJ
I opened in the past assembly which contain many parts with FTA... I could not actually read any as they were on top of each other and I could not see the geometry because there was way too many FTA around...
If I had my way I would keep them in show but i will have them in some known layers so I can quickly remove them from the 3D with a visualization filter without actually modifying the files.
There are pros and cons in every situation ask yourself your constraints, your wishes, your options.... then make a wise choice.
do you understand my previous post now?
Let's say you'd put them in layers. What'd be the next scenario?
Making that particular layer invisible?
How would the future users access them, if neccessary?
MZ7DYJ
Users could use filters to have what they need...
Eric and MarkAF are right in what they told about working with layers, in some cases is really good to use them but this should be a way of work company procedure from the very beginning. If is done later on, is additional work/time.
Fernando
https://picasaweb.google.com/102257836106335725208
Create a capture that has All Annotations, Then a few Captures showing only certain annotations at a time & views that are appropriate and clean for those annotations, then create a No Annotation or Engineering Only Capture that you keep the part saved in.
