3D PDF print on NX
3D PDF print on NX
3D PDF print on NX
Hi all,
How can I customize NX7.5 for a 3D PDF printing.
Adobe 3D V8 is the best software?
Thanks.
RE: 3D PDF print on NX
Are you simply looking for a 3d model on a 2d sheet of paper?
Thats what i use. You will run into version issues if it wont convert just make a parasoild of your model and convert that instead of the .prt file
Ryan Lee
Design Engineer
If you can think it it can be modeled
Just want 3D model with PMI data, maybe JT format is better?
I assume that JT format would be better.
You will probably need some third-party software to do what you want with PDF.
Ok and how can I see the PMI data on JT2GO?
I have entered some PMI data on NX and I can't see it on JT2GO...
Using JT2GO:
1. Tools->PMI
2. PMI->Filter Configuration
3. Make sure "display all" is selected & Click OK.
Jeff
