Reduced flow rate of existing pumping system
How is it possible to determine a reduced flow rate for the purchasing of a new pump, as the old pumps do not have to supply the flow rate that they were designed for anymore, thus just wasting energy and water?
RE: Reduced flow rate of existing pumping system
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
That is a sure fire way.
Let the tank run down as far as you want. The longer you can wait, the closer you'll know the minimum flowrate you must have.
