Add image to drafting journal
Hi guys,
I'm looking for NX Api function to add image into drafting sheet. Any idea?
RE: Add image to drafting journal
Insert -> Image...
...where you will be able to insert either a .jpg, .png or .tif formatted image file onto the face of the drawing. Once placed, you will be able to drag it to the desired location, rotate at 90° increments, resize the image or change it's aspect ratio (after toggling OFF the aspect ratio lock icon) using the handles shown when editing the image. Note that this image is static and will NOT update if the original image file is edited.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
CODE
www.nxjournaling.com
When it inserts image, journal changes the size (or scale) of the picture. In format A4 it's ok, but in A3, A2 it's 2 times bigger. (Or mayby in A4 is 2 times smaller)
I am also wonder if its possible to define image size and image name during inserting image into drafting (with image name i would have chance to check if image is jet in drafting)
ufs.Drf.imageData? ufs.Drf.askImageData?
I'm using NX 8.0.3.4.
I've been looking at the initialize image data function in the help file, but I don't see an obvious way to associate that to the image that is being imported. I'll look into it more as I get time.
CODE
