Control area for flammable liquids
If a control area is built to store flammable liquids because they have exceeded the allowable quantities in their main production area, does the fire sprinkler system in this new control area need to be specially designed to handle the flammable liquids? IE, the new control area has an ord, group 2 design (small pipe and heads). Is this sufficient, if other aspects of the control area are in place such as 1 hour walls?
RE: Control area for flammable liquids
Based on the number of variables I've thrown out, you may want the permit applicant to seek a Technical Report and Opinion under IFC Section 104.7.2. Internet forums can't always solve the issue of the day.
