Zoom and angle redering
I am pretty new to the rendering side of things. I have been fudging for a year or so but now I need to create a bunch of renderings of product and everything needs to be stadardized. I have about 10 products that I need to render and the scale of the products all needs to be the same. I also need to get the parts all oriented at the same angles. I can handle the angle orientation but how do I set the zoom.
RE: Zoom and angle redering
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
Cheers,
Anna Wood
SW2012 SP4, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
For your need, insert all the parts into one single assembly. Now set the orientation and zoom as required. Hide all except one. run the rendering, then hide that and show second. Repeat.
Deepak Gupta
CSWE, CSWP, CSDA
SW 2012 SP5.0 & 2013 SP 1.0 EV
Boxer's SolidWorks™ Blog
SolidWorks™ Rendering Contest
How many total Orientation Views can you have before crashing out SolidWorks I believe this was still an issue in 212 I think it went to 24-32 or so then it went Crashy-Crashy. I may be wrong but I remember someone mentioning this as an issue at a SWUG meeting.
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
Deepak Gupta
CSWE, CSWP, CSDA
I had never used cameras before I would just get a good view on the screen and then render. I sure wish there were some tutorials on Photoview. I only use it about once every couple of months but it is usually a rush job so I never really get time to actually learn the software it is more of get it good enough. Although it is good enough that people like the renders better than the actual pictures of the parts.
Thank you everyone for your feed back and help,
Glenn
http://www.axiscadsolutions.com/guides/
Cheers,
Anna Wood
