Copy/Paste problems
Copy/Paste problems
Has anybody come across a problem copying and pasting in Draftsight? If I copy some linework, it seems to paste something I had copied earlier and not the last thing I copied. If I switch to another draftsight file, it will then paste something else I had previously copied in that file (I really can't make sense out of what it decides to paste). I can't get it to paste what I last copied!! Extremely frustrating.
RE: Copy/Paste problems
OSX 10.8.2 | DS V1R2.1
Often enough to be really annoying, DS seems to pick a radius other than what I pasted to make the circle.
I.e., the paste operation, I swear, puts the right number on the command line, but the circle gets drawn with some other radius. Luckily, the error is typically huge, i.e. the circle is either half-ish or twice-ish the desired size.
At least I think the error is huge. I probably should go back over the drawing and recheck every damn dimension, in case the randomization is random.
Mike Halloran
Pembroke Pines, FL, USA
For me, it started as an annoyance. I would just keep pasting until it cycled thru to the appropriate item. Took may 3 or 4 attempts. Now, it's gotten to the point it is actually combining previous clipboard items into one. I've restarted the application, rebooted the machine and am still experiencing the issue. Next step will be to reinstall.
I have been using the new version (V1R3.1x64) since it came out, and have had no copy/paste issues with it so far.
It sounds like you have a new problem, because of the combining of the clipboard items.
