NFPA 13 Code question - Fire Department Connection
As per 2007 edition, 8.17.2.4.2 says the FDC shall be on the system side of system control, check and alarm valves (wet systems).
8.17.2.4.4 then says the requirements of 8.17.2.4.2 and 8.17.2.4.3 shall not apply where the fire department connection is connected to the underground piping.
This puzzles me. First, what underground piping - city main? Does it mean the connection does not have to be downstream of the system riser? Can the connection be between the system riser and fire line connection to the city main?
RE: NFPA 13 Code question - Fire Department Connection
If you are talking wet system only, no fire pump
You can have the tap at the main for the sprinkler supply going to the building, and have a yard FDc between the tap and the building
Just have to out a check between the tap and the tee to the FDc, so the city main is not pressurized
If you have a copy of 13 or 20 it should have some yard FDc set ups
in nfpa 13 2013 edition and, should be in earlier ones under " 8.16 Piping Installation" also check
FIGURE A.8.16.1.1.4
and
FIGURE A.8.17.2.4.4(a)
and
FIGURE A.8.17.2.4.4(b)
